Hello !
I am learning German, for that reason I am using this useful extension.
I realized that would be a great idea for the developers to put next to the translation of the word the gender (masculine, femenine or neuter) of it. In google translate. I am not an expert in coding, but I think that fore sure this information can be obtained from some website.
Thanks for your reply!
So far, I am selecting each word and then once I know the gender, I change the color of the word. So far, each German-learner use colors to learn the gender of each word, so maybe the pathway could be in that direction, on which each used could select his favorite color for each gender, then we could see the subtitle already with the color.
Also, would be great to have more colors available, or have 5-6 colors in total, but we can choose them.
If you’re saving words simply on some property like gender (tense, mood, etc ?), we can create a specific mode that will highlight with different colors (with an underline for instance) the properties you want to see. So this way you will not need to save tons of words and think about in which category you want to insert them.
Would be more than useful. In German language, the most difficult is to learn the gender of each word. I would say tense, mood, are not necessary. Just the gender: Masculine, Feminine and Neuter.
For example, use blue to highlight feminine, red (masculine), green (neuter).
I am really happy you are taking my comments under consideration! This is a real struggle for each student of this language.
Any update with the noun genders?
It would be really useful if a noun gender for German language pops up when clicking on a word (I mean to see it together with a translation, pronunciation and examples). It is possible to check it on external dictionaries. This however is time consuming and takes the “smoothness” of watching a movie/tv show away since one needs to check a freshly opened window.
This would be extremely helpful! I’m not sure if it makes a difference posting here a year later, but it’s very important in German — but also in many other languages! Eg. french, spanish, etc.
This is THE missing feature for me. I would pay for this alone - to easily see the gender of nouns in German. Whether colors, something in the popover etc, but make it easy to see.
This is really a critical feature. It would also be good if we could edit the cards ourselves so that we can add information that is important for us. You could create an info field for example or even better give use freedom to create fields ourselves like in Anki. That way we could add the gender ourselves.
Gender and other grammatical info would be very helpful for Polish and I think also other slavic languages. What cases are the words in, what gender, etc. What part of speech is this word? Are you using spacy on your backend? Have been playing with this and it is very good for Polish.
