I have been trying for a whole day now to get the extension to work with Netflix, but the page simply crashes every time I try to use it. If I uninstall the extension and try to watch Netflix, it works fine. However, I get an “error_code_hung” message after the page becomes unresponsive every time I try to load the extension while watching Narcos.
Hi, please check if you have any other extensions installed and try disabling them. Also, does it only happen for Narcos, can you try another movie? Thanks
