The LR button does not seem to appear on my youtube at all Processing: image.png…
Everything seems to be working just find on Netflix, unclear what the issue might be on youtube
Hi, please check these: Language Reactor (under “Extension button is not showing on Netflix or YouTube, or both”), let us know if you still have the problem.
experiencing the same problem. tried out your recommended solutions but still no success
Same here. Just noticed On/Off button not available in Youtube. Netflix kind of.
Same problem here. Also tried solutions above but not working at all.
Hi! I have same problem with Languadge reductor in YOUTUBE. there is not available buttton On/Off , dont see subtitles. I uninstalled and installed the program again Nothing work(
I am also experiencing the same problem. The button does not pop up, I reinstalled the extension but no luck
YouTube stop working! Tried both Google Chrome and Microsoft Edge, Both are not working with YouTube.
Today the extension had stopping working. Please, the extension is really helpful.
Me either. netflix work well though
Same problem。
Please I need it。
Same problem here.
Did Language Reactor automatically update itself? Or YouTube makes the change and Language Reactor could not handle the HTML?
The same problem here.
No Language reactor button.
Waiting for the solution.
Thank you.
same problem… wating for the solution too
Same problem, waiting for the LR team ,can fix this bug.
Thanks.
I have the same problem on youtube !
The same problem with YouTube…
I got same problem…I got same problem…I got same problem…I got same problem…I got same problem…I got same problem…
The Same problem with Youtube
The bug has been fixed.
If you still don’t see it, please remove the extension and re-add it to your chrome - link
