Bug keyboad shortcuts
Keyboard shortcuts aren’t working.
Could you tell me how to fix this.
*Only the speed controls work.
Using Chrome on Windows 11; extensions and Chrome are up to dated.
Hello @sunny_sun, thank you for your request!
Do the shortcuts not work only in the extension, or on the website as well?
I don’t see any issues on our end right now. Try clearing your browser data and using incognito mode.
Let me know if that doesn’t help.
Thank you for checking.
It works fine within the extension itself, but it does not work on the website.
I tried clearing the data, but the same issue persists.
I therefore uninstalled and reinstalled Chrome.
I also tried using Incognito mode.
The keyboard shortcuts are not working.
I have also checked the Windows 11 update status.
I have two PCs, and both are experiencing the same issue.
@sunny_sun just to be clear, you’re talking about these shortcuts, right?
Please send me a link to an example where this doesn’t work; perhaps the problem is in the practical material.
Dear YANA,
Thank you.
I apologize for the lack of clarity in my previous explanation.
When watching Netflix, the area marked in red does not respond (though it works fine with YouTube).
I tried pressing every key on the keyboard, but there was still no response. It used to work perfectly before…
Do you have any idea what might be causing this?
@sunny_sun, unfortunately, I still can’t reproduce this issue at the moment. Could you please tell me your screen resolution? It’s possible that the extension is interpreting your desktop as a tablet.
Dear Yana,
Thank you.
The screen resolution is 1920x1080.
I hope that changing the resolution will resolve this issue…
@sunny_sun thank you for your reply! I think this is the most likely case, but in that case, the touch control area should appear. Therefore, this issue needs to be fixed. Thank you!
Dear Yana
Thank you for your reply,
I will wait for the issue to be resolved.
Let’s keep in touch.
