Language Reactor becomes unclickable on Netflix when Nikflix (Household Bypass) is enabled
Hi,
I found a possible compatibility issue between Language Reactor and the Nikflix (Household Bypass) browser extension.
When Nikflix is installed and enabled, Language Reactor still appears on the Netflix video playback page, but its interface becomes unclickable/unresponsive. I cannot click the Language Reactor buttons or interact with its controls while watching a Netflix video.
Steps to reproduce:
  1. Install and enable Language Reactor.
  2. Install and enable Nikflix (Household Bypass).
  3. Open Netflix and play any video.
  4. Try to click the Language Reactor interface/buttons on the playback page.
  5. The Language Reactor controls do not respond to mouse clicks.
If I disable Nikflix, Language Reactor works normally again, so it seems that Nikflix may be interfering with Language Reactor’s UI or click events on the Netflix player page.
Expected behavior:
Language Reactor should remain clickable and usable even when Nikflix is enabled.
Actual behavior:
Language Reactor is visible, but its controls cannot be clicked.
Could you please check whether there is a conflict between the two extensions, such as an overlay, z-index, pointer-event, or Netflix page modification issue?
Thank you!
Nikflix (Household Bypass):https://chromewebstore.google.com/detail/nikflix-household-bypass/knjoabokknkpkhbbdclmnjcoeedmgema
Hi @adonis233liu, thank you for the detailed report and clear instructions on how to reproduce the error - it really helped a lot!
I’ve forwarded this to the team for review. Our team will look into this issue.
