Hiya, I’ve been using LLN for a while and I’m not sure if this is only on my side but my LLN doesn’t seem to work with Netflix Party. The subtitles are stuck on the first subtitle and doesn’t update. Is there any fix for this?
Thanks in advance~
Thanks in advance~
mine too here, exact problem, not only you. Plus you can’t full screen and the screen was cut a bit.
