Add more than one word to the list of words to learn. for example, “turns out.” Currently, you can only add one word at a time, which defeats the purpose.
Hello @Henrique_Lucas, thank you for your request!
The feature for saving expressions is currently under development. For now, you can save the combinations of words you need via the Dictionary. They will be saved in the ‘Saved Phrases’ section. You can then practise using them in PhrasePump, for example.
To do this:
- Open the dictionary in the top right corner
- Enter the expression you want
- Click on the star next to the expression and its translation
That’s it - the expression has been saved to your Saved Phrases section and is ready for you to practise.
