ASR subtitle is not working
The ASR French Subtitle is way off (Netflix, Google Chrome, Mac, USA, LanguageReactor Pro).
Netflix Audio: Ils y sont pour rien !.
French CC Subtitle: Ils y sont pour rien !.
ASR French Subtitle: Ils n’ont rien à voir là-dedans.
Netflix show: I Will Find You, S1:E2 at 10:24.
The original audio is in English, I changed it to French. I still see subtitles when I select ASR but the ASR does not seem to match the foreign audio. I thought the ASR was supposed to match what was being said. Please advise.
Is there going to be a fix for this? I thought the whole point of the PRO version was to get the test to match the audio.
Hi @Kimberly_Norton, thank you for the detailed report. I see the problem lies with the extension. You’re right - this is a bug, not expected behavior.
Most likely, the ASR feature in French isn’t transcribing the French audio track selected by the user because of the cache. Instead, it’s generating the transcription based on the original English speech and then translating it into French. This explains why the output makes sense but the wording differs from the dubbing.
I’ve reported this issue to the team, and we’re currently investigating the cause. As soon as we have a fix, we’ll post an update in this thread. Thank you for your understanding!
