Custom Dictionary Opens in a Separate Large Window
hen I configure a custom dictionary and click on it, it opens in a large, separate window every time. This creates an inconsistent user experience and is inconvenient.
Expected Behavior:
Clicking on a custom dictionary should open it in the same popup window or interface used by the default dictionary, rather than opening a new, separate window.
Actual Behavior:
The custom dictionary opens in a large, separate window instead of using the existing default dictionary popup.
Requested Fix:
Make custom dictionaries use the same popup component, layout, and behavior as the default dictionary. The dictionary content should change according to the selected dictionary, but the popup interface should remain consistent.
