Hey i am a pro member and this site stoped working. it says erroe loading
Same here, video file options gives the same error
same here but i am not a pro memmber.
Just out of nowhere I am getting “error loading data” for right click on any word.
The window with error does not not show any dictionaries at the bottom.
When trying to set vocabluary level I am getting “error loading data” as well.
All words are now lost their colorization and I can not change it under the settings.
Working with netflix. Checked javascript, removed cookies - nothing helps.
Tried working from another machine - all the same.
The last thing I did was to try to export something.
I don’t think it is related to configurations, seems like a server issue. Dictionary link Language Reactor uses, does not work:
Now I can not changeany settings at all. It just silently goes back with whatever. Wrote n email to support team.
I have the same problem, today language reactor is failing
I’ve experienced the same problem all day. When I hover over a word, it says error loading data
It seems to be working again. Yes!
indeed its working now
