[Remove this topic template after you’ve carefully read it
How to copy paste youtube link?
[End of topic template]
Can you tell me a little more about it ? What do you wanna do ?
Thanks
I want to copy a link from youtube and paste to app, then study on it , but there is no web browser like area to paste the link and open
Hey, I dont need to do it, when on YouTube you supposed to see a Language Reactor toggle and you can turn it on.
Make sure the toggle is on like in the screenshot below
I understand that , i forget to mentioned that on android tablet , with app i cannot do that , i want to use app on android
The problem is on android , thanks
SImply copy the link from the link bar of your browser
You do not understand me ,even if youtube share your app is not seen, probably i downloaded out side of google play
On youtube section , no adress paste page, it only reccomends some videos
All above problem is on the android platform, may be you find a solition to this or simply add the program on googleplay and i will download from there and try
This extension works on Chrome. On android you wont be able to see it - especially if you use YouTube app from your device.
