how to obtain a tanscript of an episode or movie
I don’t know how to do [obtain a transcript INSERT YOUR ACTION ]
Hello @Fred_Johnson,
You can use the export function, which is available for each practice: Media section, ChatBot, Saved section, YouTube, and Netflix.
To do this, click on the Export button in the upper right corner of the desired section, set the desired preferences, and download the file in the format you need.
