Netflix subtitles get messed up after ads
Hi, I’ve noticed that when an ad comes on during a Netflix show, Language Reactor keeps showing the show’s subtitles as if it’s still playing. Once the ad finishes, the subtitles are out of sync with the show.
Is there a way to fix this? Thanks!
Hi @kebin7927, thank you for your message! We are aware of this issue. We have looked into it, but Netflix does not provide accurate data on the duration of commercial breaks, which makes it difficult to fix the synchronization quickly. We are still working on a solution to this problem and will update you on our progress as soon as we have any. Thank you for your patience!
