Quit Fullscreen When Looking Up Words
When using the YouTube feature (https://www.languagereactor.com/c/en/yt/t_yt_mix_en), clicking on a word to look up its meaning automatically exits fullscreen mode. This is extremely frustrating and makes the experience unnecessarily inconvenient.
What I don’t understand is why this behavior exists in the first place. I’m simply clicking on a word to check its meaning, not asking the application to exit fullscreen. The Video File feature (https://www.languagereactor.com/video-file) handles this perfectly fine, allowing me to look up words without leaving fullscreen mode.
Why can’t the YouTube feature behave the same way? Why introduce this unnecessary limitation when the exact same functionality already works perfectly in another part of the application?
This inconsistency makes no sense from a user’s perspective. I should be able to look up words while watching a YouTube video in fullscreen, just as I can when using the Video File feature. Please consider fixing this behavior so that looking up a word doesn’t automatically interrupt fullscreen playback.
Hi @Obey_Rush84, thank you for reporting this. This is a known bug that has been reported for a fix.
As a workaround, you can now open the dictionary before entering full-screen mode. This may be inconvenient, but it’s only temporary. In this case, clicking on a word won’t exit full-screen mode, since the dictionary will already be open. Thank you for your understanding! :raised_hands:
Hi, I already knew about this, but unfortunately, I wouldn’t really consider it a suitable workaround for my situation. I mainly use Language Reactor for its vertical view, which allows me to see all the subtitles on the right side of the screen. Keeping the dictionary open would cover that area and defeat the main purpose of using this feature.
So, unfortunately, the only option for me is to wait for an update that fixes the issue. Hopefully, it won’t take too long. Thanks for the response!
@Obey_Rush84, this is already in the process. Thank you for your understanding.
