The LR button has disappeared and cant be used on Netflix. It still works on Youtube and has been allowed to function for both sites but for some reason Netflix doesnโt work.
Please can you @ me if they answer you, please? I have the same issue as you.
same problem here. i was still using it last night on 7th september and now 8th september the button disappeared.
me too. please check the problem for users
I am having the same problem.
same problem, too.
Hope someone can reply soon.
Same issue here, has anyone found a solution?
Same problem here. Hope LR able to fix it asap.
์ ๋ ๊ฐ์ ๋ฌธ์ ๊ฐ ์์ต๋๋ค!.. ์ ํ๋ธ๋ ๋๋๋ฐ ๋ทํ๋ฆญ์ค์์๋ ์๋ ์ใ
I have the same problem tooโฆโฆ
sameee problem here.
I see I am not alone with this problem. I hope someone will deal with it.
์ ๋ ์๋๋ค์ ;; ์ด์ ๊น์ง ์ ์ผ๋๋ฐ ์ค๋ ๊ฐ์๊ธฐ ์๋์โฆ
same with meโฆ ugh!! button is not there as of 1:15am, central time, 9/8/2021
Same hereโฆ Itโs not working at all.
Even though, I deleted the program and reinstallโฆ still not working.
Guys. Does the LR button means left and right? by the way. i disappeared my hide border button.
friend, the LR button just appeared for me yesterday at night. Did yours too as well? I did nothing. I just gave up and after class I decided to keep watching a serie and it just worked.
Yes, I also contacted Paddle,net support (to report this issue) and I was told itยดs been already fixed. It should work for everyone now.
