I am currently in the USA and having a problem installing the Language Reactor Extension on my toolbar. After I hit ‘install extension’ (Language Reactor) in the Chrome Extension Store, I receive the following ERROR MESSAGE - “Package is Invalid: CRX_FILE_NOT_READABLE”
Hello @Catherine, thank you for your message!
This error usually means that Chrome cannot properly read or download the extension package from the Chrome Web Store, not that the problem is related to Language Reactor itself.
Try the following:
• Clear Chrome’s cache
• Restart Chrome
• Temporarily disable your VPN, ad blocker, or antivirus
• Update Chrome to the latest version
• try a different Chrome profile or Incognito mode
Also, could you check if other Chrome extensions install properly? This will help determine whether the issue is specific to Language Reactor or to Chrome itself. Thanks!
