Sometimes, when you click on a word and try to go to the dictionary, the extension modifies the word that is actually searched on the dictionary, e.g., converting verbs to the infinitive, plural to the singular form, etc. This might be useful in some scenarios, but I’ve never found it useful. Can you please add a toggle to disable this functionality? When I click on a word to be searched in the dictionaries, I want to search for the exact word as it appears without any weird conversions.
I’ve noticed the issue for a long time now, but just an example (that happened right now). I clicked on “teubée” to open on Wiktionary, but the extension searched for “teuber”. teuber doesn’t exist, it’s not a verb in French. The words “teubé”/“teubée” do exist in French and they mean dummy/dimwit.
Secondly, the Reverso Conjugator highlights a specific conjugation if you search for the non-infinitive form of a verb. If I click on the verb “as” in French to open in Reverso, I want it to search for “as” on Reverso so it can be highlighted, not the infinitive “avoir”. Otherwise, I have to do a CTRL-F to find “as” which is annoying.
Please fix this.
