When I use PhrasePump in the Finnish language, I get the error: “Network Error, please check your WiFi. Load audio failed.” It doesn’t load the audio either. However, my network connection is perfectly okay.
It takes so long time also to show the next sentence! Basically, not useful!
              I have same problem with Finnish and Spanish.
I am using Phrase Pump in Finland.
              Bro Sina, I noticed now the malfunction happens with “Suggestion” and “Practice” but not with " quiz".
So I temporarily chose just " Quiz", waiting for other feature malfunctions  to be solved
