I cannot left click. The website says this. Does it help to solve the problem?
I use this extension for youtube.
Hello @neo
Which browser are you using, and what version?
I can see that it works correctly in Google Chrome, which is the official browser that supports extensions. In other browsers, the extension may not always function properly.
Same issue for the last couple weeks. I can hover and see the definition but no popup dictionary anymore ![]()
And it doesn’t let me mark words as known/unknown when clicking on them either- Youtube as well. Videos and text on lang reactor still allow me to see the popup dictionary but no other sites.
rightttt. I hope yana can help us with this issue please…
@neo I have the same browser version, but everything works fine for me. Try disabling all other browser extensions and leaving only the LR extension enabled. Sometimes other extensions (such as ad-blockers) can interfere with Language Reactor’s normal operation.
Let me know the result ![]()
i have the same problem
I did have the ad blockers, so I disabled them as well as other extensions. But it still does not allow me to left-click on the word.
it says this today if this is related:
@neo please send us your email address linked to your account so we can figure out what the problem is
I wanna privately share my email. is it possible
@neo yes, sure - yana.baklan7@gmail.com
I have the same issue on Chrome, was this figured out?
not yet. i dunno if it is gonna be fixed…
Has it still not been solved?
no. I want to know when the next update is to fix this issue.
Yup. still no solution and it’s been over a month. I pay for this service mostly for this Youtube feature. If it’s not fixed soon I will not be renewing.
