Word popup no longer appears on click
The popup with grammar and the AI voice reading the word is no longer present.
When I hover a word in my target language I get the small window with the word definition and [mark as read] [mark as known]. But I can no longer CLICK the word to get the longer Lexa AI definition with grammar and the voice reading the word. This was really important to my workflow.
Brave browser on Youtube.
I have everything enabled, changed no settings, but some update recently made the word click popup no longer show:
Also, the [Mark as known] [mark as learning] buttons no longer do anything. They dont add the words or change the color
Having the same issue. Other threads have suggested disabling all extensions, but this has zero effect and the problem persists.
Also on Brave.
Edit: Disabling the Brave shield does fix the problem. Gonna have to do some digging to figure out what exactly the Brave shield is blocking to cause the app to break.
Thank you for your message. I see the issue with clicking on a word in the subtitles in the Brave browser. Unfortunately, we don’t support this browser. At the moment, the extension is officially supported only on Google Chrome. This feature works correctly there.
I’ve reported this issue to the team; perhaps we’ll be able to fix it quickly. :raised_hands:
still broken actually
-__- please give more support to Brave
For some reason in a Linux laptop, LR &YT work correctly on Brave but not on Chrome. Latest updated versions both.
