- It doesn’t work with any yt video
- Russian-English
Clicking on a word’s buttons (known/learning), the word itself to open the dictionary or the star does nothing.
@ampi
Please disable all browser extensions except Language Reactor. Sometimes other extensions block Language Reactor from working properly.
Make sure that the “Study language” setting on the website matches the language in which you are saving the word. For example, if you are saving a word in Russian, the “Study language” setting on the website should be set to “Russia.”
Also, make sure that your words are sorted by date (from newest to oldest—the down arrow), see screenshot
Yes, the first advice helped me. I turned off Ublock and LR started working properly. LR works well with other ad-blocker as I discovered.
