Youtube not allowing selection of words
I recently started using Language Reactor for russian and it was working well. but for some reason on my desk top (Windows, Brave Browser) i became unable to select words on youtube videos or to tag them as known/learning. other than that it all seems to work fine, it will blur subtitles, it will pause each sentence, and it will even show translations on hover, its just that clicking on any of them doesnt do anything. I have also started having this problem on my macbook in chrome. it seems odd that it would be an issue across platforms like that so I’m assuming it has something to do with my account.
I should add that if I use the upload media option that everything works normally. After experimenting some more, it seems like I can change learning words to known, but nothing else. and i cant get ai explanation of any word still. again, the problem is across devices and across browsers. Netflix does seem to work in chrome as expected, just youtube causes problems.
Hello @Dutch_Lane,
Thank you for your message. We are already working on fixing this.
You’re not alone, I’m having the same issue.
Same problem over here, even with russian too
