Although in windowed / minimized view it works, but in fullscreen it does not:
making you have to click each word you don’t know to get the translation (and that is slow)
The Ognjen will fix it, stand by.
I have the same issue, I hope you can fix it soon. suggestion: could you enable opening the mini-dictionary in a small window at the top?, like on YouTube, instead of having it take up the entire sidebar. That would be very useful and it would be more practical to use.
