I don’t know how to change dictionary order.
See the photo, I want change the default dictionary “RE” to GI or WI or Ca, How can I do that? I can not change the order.
@ZZP Unfortunately it is impossible to change external dictionary order. But you can get quick access to the last used external dictionary by holding Shift while clicking needed word
If i holding Shift while clicking needed word ,will open a new tab,that’s not what i want.
@ZZP You can change the order of added dictionaries. (which you add in the settings).
The order of default dictionaries cannot be changed
