Language Reactor Error: Failed to retrieve linguistic data: NETWORK_ERROR Lang: en
When I open a video in youtube, this application always show the upper words.
And it couldn’t show vocabulary one by one.I can’t click the word,and I also can’t look up the dictionary anymore.
Could you tell me how to fix it ?
Did you get your problem solved, I had the same problem
yeah same here, no fixes yet?
Just deleted language reactor from the extensions and then reinstalled it once i restarted my laptop and now it works!!
If you are using a VPN, disable it and that will most likely solve your problem.
