When I use LR on Netflix, the volume becomes so low I can hardly hear it. Anyone knows how to resolve this issue? Thanks in advance. (I am using a Fujitsu laptop)
Some dub indeed aren’t loud enough, the fix I usually implement is using headphones or anything amplified connected to the PC (tv, hifi,…) but the problem with that is that when you click on the words for pronunciation it’s SUPER loud.
If there was a way to implement a volume bar for the pronunciation of words it would be great…
NOW, I thought about how VLC had a volume booster and thought maybe there was volume booster add-on for browser and well, it does
I find one for chrome (therefore compatible to edge, and I guess any chromium-based browser as well)
Volume Booster - Chrome Web Store This one seems to work better though, and is better noted : Volume Master - Chrome Web Store
Probably on average the word/phrase tts is a bit too loud… hmm, I didn’t realise this.
I do normalise volume when extracting clips from movie audio for saved items.
Okay, I’ll put this on the todo list, thanks.
