The current UI is focused on keyboard-wise. Could you add mouse friendly button just above the caption so I can save the time for moving the cursor to the left when I only want to or need to use mouse? thank you very much.
@JH_Ryu, thanks for the suggestion! Could you clarify which button or action you’d like to have above the captions? Next subtitle, Repeat, Previous subtitle? That would help us better understand your request. Thanks!
Hi Yana, i was asking for all the functions you can use with keyboard.
