Netflix subtitles stuck loading in Language Reactor
Video link: Watch What I Like About You | Netflix
Country/Region: Buffalo, New York, United States
Language configuration:
Native language: Chinese
Learning language: English
I’m having an issue with Language Reactor on Netflix.
When Language Reactor is enabled, the subtitles on Netflix stay stuck on loading and never appear. However, if I disable the Language Reactor extension, Netflix subtitles work normally again.
The issue only seems to happen on Netflix. Language Reactor works correctly on YouTube — subtitles and translations load normally there.
I have already tried reinstalling the extension, but it did not solve the issue.
Could you please help me figure out what might be causing this problem and how I can fix it?
Thank you.
Try refreshing the app. It usually takes a full 2 minutes for the subtitles to surface.
