I don’t know how to add manually phrases
Thanks for your help ![]()
You can manually save phrases by:
Note: Please ignore the small “box” with the green light bulb and G logo (in the picture, I have an extension called “Grammarly,” so it shows up there). It’s not part of the Reader/Text tool experience or Language Reactor. ![]()
To save phrases, click on the star (
) next to a sentence/phrase (which appears when you hover over it with your cursor).
To save words, click on the word in your Target Language and mark it “Learning” / “Learned” or even “Don’t Learn” (but “Don’t Learn” words won’t show up in PhrasePump, so I wouldn’t recommend it for this instance, but it does show up in a list form that you can access).
Here is a help page on this (though it is a bit outdated as of this post): Language Reactor - Saving Words Tab
I hope this helps you (and any new users that come across this in the future)!
