I have collected a lot of words, but the words trained in phrase pump have no relationship with my collection. I want to know if I can only train the words I have collected.
Thank you!
Normally PhrasePump only shows you the “orange” marked word. But you might have, in your settings, automatic “marked” word depending on the vocabulary level (See image) :
To modify this, only go to your settings, and disable the 2nd one. Thanks to this, only words that you marked should appear in PhrasePump.
You can see them on the page “Saved” them “marked words”
Have a good day
