PhrasePump does not just show words I am learning
I don’t know how to do set up PhrasePump in order to just practice the words I am learning.
I really like the concept because it is interactive and no so boring like anki; but this shows me like 5 sentences with words I am learning, and 15 show me recommended sentences. I click on no suggestions and new elemens is in 0% but I sill just see few times the words I save to learn.
I’m having the same issue (if I understand your post correctly).
I want to review/practice my Saved phrases only. I don’t want to see any suggestions LR thinks I might need to learn.
This seems like an easy and obvious feature, so maybe I’m missing something. Any help would be greatly appreciated.
@Justrandom @David_Solis
You can disable the recommended words in the PhrasePump settings, to do so:
  1. Go to the PhrasePump section
  2. Click on the Settings drop down list
  3. Set the Suggestions switch to off
@Angelina_Kalinichenk - this is a helpful post.
  • LR admins / programmers: @admins
    Many users have expressed frustrated with the flashcard options.
    While it is better to learn vocab in sentences, it is also preferable at times to learn words individually. One could easily justify keeping the membership if they did not have to rely on a second subscription service in order to use simple flashcards. Adding a simple flashcard option to PhrasePump or as another section would ensure my continued subscription.
