just wanted to share that language reactor works well with ms edge “canary” on android.
canary is the developer version of Microsoft edge browser with full extension support.
unless it’s changed, to add extensions you need to:
How to Install Any Extension on Microsoft Edge Canary for Android
News
reddit
OP
7mo ago
Edited 7mo ago
Edit: Before beginning, make sure to go to edge://flags/ and enable the “Android Extension” flag. Go to the “All menu” to see the extension button. Here’s a quick video on YouTube showing how to enable extensions for Edge Canary:
Instructions:
Open Microsoft Edge Canary.
Go to Settings and then tap on “About Microsoft Edge.”
At the bottom of the screen, tap on the Edge build number (e.g., Edge Canary 125.0.2487.0) 5 times to enable Developer Options.
In the Developer Options, tap on “Extension install by id.”
To find the extension ID, follow these steps: a. Open the Microsoft Edge Web Store (Microsoft Edge Addons). b. Find and select the extension you want to install. c. Look at the URL in the address bar. d. The extension ID is the long string of characters at the end of the URL (e.g., jbkfoedolllekgbhcbcoahefnbanhhlh for Bitwarden).
Enter the extension ID into the “Extension install by id” field on your Edge Canary browser.
The extension should now be installed.
