A request due to ''Phrase Pump''
To be honest, I don’t find the Phrase Pump feature very functional or educational. It really needs improvement. There should be a better system that actually helps us learn — both from the words we’ve saved and from the full vocabulary list.
Right now, Phrase Pump feels quite ineffective, and I think you need to work on improving it. Saving learned words and being able to review them is great. It’s also nice that we can access them easily and listen to their pronunciations — especially when they come from Netflix, where we can even hear them as they’re used in the original scene. That part is really impressive.
However, the Phrase Pump itself doesn’t add much value at the moment. The system needs to be reworked — it should offer more learning options, more interactivity, and a more engaging experience overall.
I recommend checking out my review on PhrasePump. I hated it too, passonatly, but its found a place in my language studies.
