Anki export is not very good
I don’t know what’s going on here. Anki is not picking up things correctly:
I’m following the instructions. Why are only 3 fields exported? Why is the “front” field contain both languages, and the “back” field is “word-naked lang-zh-CN netflix noun”? Language Reactor works so well for me mostly except this important part.
LR’s Anki export is the worst. You have to make sure you’re using the correct card template. Its still using the old name because the template hasn’t been updated since 2021…but it still works.
You can find the template here: Learning with Netflix Template (Language Reactor)
I’d suggest using an addon like asbplayer to create Anki cards with.
Its free and works very well with Netflix and other sites too.
asbplayer
Unfortunately, I don’t think it has anything to do with the template. Anki still only recognizes 3 fields in the export:
You might think exporting them as Anki would work, but again, I can’t stress enough how unintuitive the exporting feature is.
You have to export as a CSV file, then choose the LLN template.
