Hello ,
The automatic pause causes the browser to stop showing the Netflix content.
Please help (SOS)
Hello ,
Please help (SOS)
Hi, I couldn’t reproduce this. Can you describe exactly what you did and what happened?
Hi
When I activate the Automatically Pause after 10 minutes the content of Netflix stops and does not respond.
I am sure its the Automaticlly Pause because when its not activated the content has no issues. I need the Automaticlly Pause to be activated because it helps me much to study Spanish.
I hope you check this issue as soon as possible.
By the way this issue keeps happening for the last 3 weeks, It didn’t occur before that.
The problem cannot be solved by reloading the page.
Thank you so much
I’ve done some detailed tests, but couldn’t find any issue here…
In case you have any other extensions installed, could try disabling them just to see if that helps?
Thanks for your response.
I noticed yesterday (after 18:00 GMT) the issue didn’t occur.
I hope it disappeared for ever.
Let’s see these days.
Thanks again
