Blurred subtitles, youtube
Hi,
Blurred subtitles on youtube (every phrase), if you hover on them, it becomes clear (french arte channel, if it’s important). It’s annoying, as you can guess.
I know about “hide subtitles” toggle in settings, the problem is that I don’t have it in my settings.
Hello @Sapere_Aude,
This should be displayed in the extension settings, not the website settings (see screenshot)
To disable blurring, select “Disable” under “Hide subtitles”
If you’re still experiencing this issue, please send a screenshot of the subtitles and your extension settings. Thank you!
