Hey there! I’m very grateful to you for your work on this extension. I was wondering if it was possible to add keybinding changes to the settings? I’d really like to be able to change them up a bit so I can do all the keyboard control with one hand.
Did you find a way? I’m also having an issue as i use the same keybinds for video speed controller.
try this. although i agree we need that feature INSIDE the app
Ditto very nice extension. Is there a way to change the keybinds somehow? default ones conflict with other chrome addons.
