Extension button is not showing on YouTube
Language Reactor extension is suddenly not showing on bottom of Youtube Video Panel.
I don’t have Netflix to test it there.
[EDIT: Creating an alternative Chrome account brings back LR, but when I logged into my LR account the extension disappeared when I restarted Chrome. I can see from previous posts here that this is a recurring issue. Is there another solution for this?]
All permissions are enabled in extension settings.
I’ve tried multiple videos:
I’ve tried multiple browsers (Chrome, Brave)
And on two separate PC’s (windows 11)
I’m based in Ireland. I’ve tried using VPN, same issue.
Language config I’ve tried is Chinese (Simplified) English translation.
I signed up for a paid subscription two days ago. LR was working perfectly up until I used the Phrase Pump for the first time. From there, I went back to YouTube and the extension was no longer showing.
I then tried another PC, installing LR, but I may have opened Phrase Pump before trying on YouTube so I can’t test whether this is the issue.
I’ve tried uninstalling and re-installing the plugin.
I’ve tried restoring Chrome’s default settings.
Update: After I create a new Chrome Profile the plugin sometimes works. But it disappears when I re-launch the new profile. I had logged in to LR.
I need to create a new Chrome Profile each time I want to use the plugin.
I have the same issue.
It is visible when I switch to another YouTube account that is not Premium.
The issue may be associated with YouTube account itself.
The developer may not have tested on a YouTube Premium account.
I hope the issue can be resolved promptly.
I do not have YouTube Premium but the problem hasn’t occurred yet this time. Main difference is I am not logged in to LR
Same, but I don’t have the patience to create a new account. I do have netflix and it is working but didn’t save any of my tagged items.
There was an issue recently on Youtube due to new anti-adblock protections, it should be resolved now. Please leave more details if you are still having a problem.
