Has anyone found a workaround for this to work on Android?
I mainly use my Android tablet to watch Netflix on the go, and I have been experimenting with several other browsers which supposedly supports Chrome extensions but so far none have worked for Netflix.
Kiwi Browser will install Chrome extensions on an android including Language Reactor and works with Youtube. The only issue is full screen doesn’t display correctly. My best guess is the wider aspect ratio of 16:10+ vs 16:9 of a standard PC is the issue. Changing the aspect ratio on an android is a pain and may require root access.
Netflix discontinued support for running in the browser on Android devices. So that’s a hard stop for now, as far as I can tell.
My guess is installing a Windows VM (or Linux, etc.) on your android will resolve both issues but again, not that easy. Working on it.
I failed to make LR work on Kiwi (I installed it but it’s not working on YouTube). It also seem that Kiwi stopped development.
