How to set up the new version of Anki. The setting indicated on the site does not work. When I click “import”, it opens the file explorer, not the settings in Anki, as it is written in the guide
@otomiru Just try to import the .csv file. To do this, first unzip the downloaded file with the exported words from https://www.languagereactor.com/. Then follow the steps in the screenshot below
Angelica, this doesn’t work for me, is there a better way to import files? And I also want to import the audio, not only the words.
Try using my guide
