Issue with Translation Showing as ‘-’ in YouTube Videos
Hello everyone!
I’m encountering an issue with the extension in Chrome, particularly on YouTube. I believe the problem is related to the “Show machine translation” option, as the video’s language is displayed correctly, but the translation language only shows as “-”.
I’ve tried several solutions, such as switching browsers, disabling other extensions to avoid conflicts, and clearing cache and cookies, but nothing seems to work.
Has anyone experienced a similar issue? Could anyone help me with this?
I’ve been having the same problem for several days now, translating from English to Spanish. I’ve tried different browsers and the error persists. Please, has anyone found a solution?
Hello @Alexander_Cabanillas
It’s better if you stay in this thread
Could you please send me screenshot of your Settings popup?
It should help me to reproduce this issue
Thanks!
Same here. All my videos in at least 3 (Italian, Russian and German) languages the translation is showing up as only a hyphen.
Nothing has changed in my settings. Just started 2 days ago.
This has happened in the past, then it mysteriously disappeared. Now it’s back again.
LR or Youtube has done something to the settings.
Same problem here, both in Google Chrome as in Edge. Nothing seems to help, from emptying browser cache to reset allllll the settings. And it’s with every language!
Hope this will be solved soon. I love Language Reactor, and it works great for language learning… as long as it works
Hi there, I’ve been having the same problem increasingly lately.
But a temporary workaround is to watch the video in a private window while the extension is enabled there also. Then it seems to work.
Hope this can also help finding the bug to solve the issue.
One workaround I am using to bypass this error is:
Go to your video → settings icon in the bottom → Subtitles/CC → select the language there as your target language → then go to auto-translate and select the same language again. And somehow this seems to be working.
