Language Reactor error: Failed to retrieve linguistic data: BAD_REQUEST Lang: en
Bug Msg:
    Pretty much all the Eng.-sub.-available shows/programs.
    T.W.
    T.R. C.N. → E.N.
Language Reactor Error: Failed to retrieve linguistic data: BAD_REQUEST Lang: ko . 유튜브 자막이 나오지 않네요. 해결책 아시는 분 가르쳐 주세요
Me too since yesterday
Confirming that I’ve had this same error for 2 days now, other languages are working but Korean is not.
This is happening on Youtube for me, I don’t use this with Netflix so I can’t test that.
I am also experiencing this problem in Brazil, I’m trying to use Youtube but it doesn’t work with English, French, Chinese, and Korean. The translation is PT BR. Will the days affected by this problem be refunded? I paid for a month, but it’s not working properly the whole day.
Also happening with Italian just on Youtube, Netflix is fine: Language Reactor Error: Failed to retrieve linguistic data: BAD_REQUEST Lang: it
That’s strange… I use it with Italian on Youtube without any issues but Korean still doesn’t work for me, it’s been at least 4 days now I think. I’m hoping a fix comes soon!
Hey, its a server failure and we are working on fixing it. Sorry for the inconvenience.
This is for Peppa Pig season 6 episode 1 The Queen/Desert Island/Perfume/The Children’s Fete.
Everything worked just fine for the first 10 minutes of the episode then it broke. I had to switch to Guoyu (Taiwan) instead of Putonghua (China) (both of these are just Mandarin) but the former has traditional characters instead of simplified so that’s a problem.
I hope this is fixed soon because I’m about to switch to another learning platform. I tried uninstalling and reinstalling already.
Thanks for the heads up with the reply, I’m hoping you are able to resolve this soon!
Cheers.
Any updates on the Youtube error Language Reactor Error: Failed to retrieve linguistic data: BAD_REQUEST Lang: ko?
This is still happening for me on Korean Youtube, it’s coming up on 2 weeks without being able to use the app with Korean. I can still see all my saved words on the website, I just can’t use the app when using Youtube due to that error.
Italian and Russian Youtube with Language Reactor are working perfectly fine for me though!
Hey guys, it should be fixed now. could you check and let us know?
It’s working now! Thanks for correcting the problem, I’m glad to be back working on Korean again.
I have the same issue…
Does it still occur?
Yes, now it is like this
For me, it is back to normal. Thanks.
nice bro) https://javascript.ru/forum/jquery/70237-zastavit-mashinu-poekhat.html
