language reactor overlaping
When the extension is enable, the subtitle bar ( not the one that is showing inside the video, a sidebar) is overlaping the play button of videos from youtube. Even when i select to hide the subtitles from the video it self, this sidebar of language reactor don’t disapier
[/quote]
Hello @sinseunggi957, the problem is most likely that the LR extension is conflicting with other installed extensions. On which side of the screen does the subtitle panel appear?
To resolve the issue, try disabling all other installed extensions except LR and clearing your browser data. Then, if the problem is fixed, re-enable the extensions one by one to see which one is causing the conflict. Please let me know the result!
i think there was a youtube update or something as this is conflicitng with the comments
