I’ve been learning French, saving unknown words to my vocabulary list.
Now I want to learn some German.
How do I separate the German vocabulary from the French vocabulary?
Do I need to create a new account?
As far as I know, you use the little expansion carrot icon
next to your current language (French) and then select another language:
This:
Leads to this:
After clicking your new language, my best guess is that it creates a “new” desktop that you can navigate to for saving words. I’m not sure, as I’m currently sticking with one language.
I know some users here are learning multiple languages, so maybe they can chime in. However, if you want to get started immediately and experiment, I wanted to drop in the above information.
Good luck!
P.S. I don’t know if doing this will separate the vocabulary out or if LR does separate the vocabulary out with multiple languages.
