This extension does not work on my chrome browser with Netflix. The lln frame doesn’t show up at all. I turned off the test button, still not working
Did you get it working again? I’m having the same issue
Did you try turning off tests?: Netflix
Unfortunatly Netflix pushes different code to different users, and it makes our life difficult.
I did try turning off tests - it didn’t work, so I logged out and back in again, and restarted my computer, etc. Still didn’t work, so went back in & turned the tests off and on again, repeated the log out and login and rebooted again, got annoyed as it wasn’t working, so left it for a few hours, then it randomly started working, so I’ve idea why, perhaps it just needed time to think
