Microsoft Edge version of TTS cannot read numbers out loud.
TTS in the Microsoft Edge version text menu does not allow numbers to be read out loud. how can tts voice be used to read out numbers?
The Text-to-Speech (TTS) feature in Microsoft Edge may struggle to read numbers aloud. You might have to change the settings in the TTS engine or format the numbers differently. Make sure your TTS settings are right, and try using the numbers in a context where the engine recognizes them.
Thanks, I’m having the same problem in chrome, how can I change the setting in TTS engine
