Netflix error
I don’t know how to do [ INSERT YOUR ACTION ]
My Netflix shows me this error (N7111-1331). How can I fix it?
I get the error N7111-1331 on Netflix. How do I fix it?
Hello @skystar0928,
You should write to Netflix support to find out or look for errors here Netflix Error M7111-1331 | Netflix Help Center
A possible error is your current Netflix plan doesn’t support watching on a web browser (for example, only on a phone or tablet).
Until recently, Netflix worked fine for me.
If I disable the Language Reactor extension, Netflix becomes watchable.
Do you know any way to fix this?
Oh, the same error happened to me. Did you fix it?
Hello @hyewon,
If you see error N7111-1331, this error is on Netflix’s end. We cannot fix it.
Thanks for replying!
