I’m Korean and I’ve studying Eng using netflix and LLN
when I started to using LLN program, netflix did not working and gave me a error message.
Error code : M7353-5101
Netflix said that I have to uninstall LLN program but I need it to study eng.
how can I solve this problem??
Hello. The easiest solution for now is to go to this page:
https://www.netflix.com/DoNotTest
And switch off the button:
That should fix it for now, until we can make an update with a proper fix.
I also suffered from error code: m7111-1931-404. Then I got the solution. I hope you will get the solution too.
People often face the error ui3012 while streaming the Netflix, this time you have to check first streaming device and WI-FI are working appropriately this would help you out fix this error otherwise check this.
