it was problem with my browser its working great rn thx
This topic is temporarily closed for at least 24 hours due to a large number of community flags.
This topic was automatically opened after 31 days.
Had a similar issue before, usually it’s either the extension not updating properly or a browser conflict. Try removing and reinstalling the extension, and make sure Netflix is opened in a normal tab (not incognito). Also check if any other extensions are interfering or if your browser needs an update. That sorted it for me.
