The extension is not working on Netflix, it does only on YT. I use Microsoft Edge and I’ve even tried to re-start the computer but nothing works, i don’t know what’s the problem, I did refresh the page so many times, and also I installed and delete the extension over and over again.
Can you try it using Chrome?
yes, I already did and nothing works
Not working in Netflix again…
Hi, I’m having the same issue with Netflix.
Netflix subtitles work normally, and I can select English (CC) in Netflix, but Language Reactor keeps showing “Loading subtitles…” and the subtitles do not appear at the bottom or in the side panel.
In Language Reactor settings, both “Netflix Audio Language” and “Netflix Subtitle Language” stay stuck on “Loading…”.
I’m using Language Reactor Pro and Chrome.
I already tried refreshing the page, restarting Chrome, checking Netflix subtitle settings, playing the video for 10–20 seconds, and turning subtitles on and off, but nothing fixed it.
It looks like several users are having the same issue today. Could you please check if there is a server-side problem?
Thank you.
Same here, the extension in Netflix doesn’t work… ![]()
